-   -   AC not working (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/120908-ac-not-working.html)
Mark_944S2 07-28-2003 09:27 AM
AC not working
Yesterday I drove the car and the AC wasn't working - no drop in air temp at all. Prior to yesterday the system worked perfectly with really cold air (new compressor 2 years ago)
The lamp in the AC switch was on, and I could hear a change in the engine note when you pressed/released the switch.
Any ideas anyone?
Thanks,
Mark
Scott R 07-28-2003 09:44 AM
Is your temp mixing system working? When you turn the temp knob does the air get hotter, then colder as it approaches outside temp?
If not your mixing flap clip may be broken.
Mark_944S2 07-28-2003 10:48 AM
Hmmm not sure, I'll try it tonight. Is it easy to fix?
Mark
Scott R 07-28-2003 10:58 AM
10 min labor and about $3 for the parts. The clip is located just above and to the side of the gas pedal, behind a black plastic cover.
CJFusco 07-28-2003 11:24 AM
what a coincidence. today i found out that my AC might actually work.
Sam Lin 07-29-2003 12:57 AM
10 min labor? Isn't that a little generous?
Sam
Mark_944S2 08-02-2003 08:43 AM
OK so I tried the temperature control yesterday and it is working fine. Hot air when set hot and coolish air when set to cold. But no change when the AC button is pressed.
Any more ideas anyone? Thanks!
Mark
Mark_944S2 08-02-2003 02:18 PM
Also the radiator cooling fans are coming on - but no change in engine note when I pull the "AC Compressor" relay.
So it looks like either relay or the A/C electromagnetic clutch
Mark
Scott R 08-02-2003 08:27 PM
Or your system is empty, jump the terminals on the pressure switch next to the dryer, see if that gets the compressor going.
Mark_944S2 08-02-2003 09:46 PM
Thanks I'll try that - but one day the system was working great, the next day nothing - it doesn't fit with a slow leak - maybe a sudden one.
I've got the compressor relay pulled to test it - will test it on monday.
Mark
Scott R 08-03-2003 09:31 AM
When the compressor front seal went on mine it lost all of the pressure in a matter of moments.
TSNAPCRACKLEPOP 08-04-2003 04:26 AM
yes, i saw the warp in the ozone layer that day.
Mark_944S2 08-04-2003 08:47 AM
Hoping its not the compressor, it had a new one from porsche 2 years ago at huge expense!
I suspect the relay or clutch.
Mark
Another944kid 08-06-2003 01:05 PM
Mine is doing the same thing and I can't figure it out. I just replaced the leaky hose, changed to R-134 (I think thats it), and it was working fine. THen yesterday it was blazing outside...and it won't work, and you can hear a relay clicking. I checked the relay and even tried to jump the relay today. CHeck connections at the compressor, and still nothing. I'm burnin up...
