944 clunking
Hello all! I recently picked up a clean 87 944 for 5200. It clunks when you let out the clutch. When going through the gears it does too. If I shift her just so it almost goes un noticed. When I'm cruising and step on it or lift my foot off the pedal she kind of chatters and clunks. From what I've read on this board it seems these problems are almost common. When I was under the car I wiggled the tranny. It moved almost a half an inch each way from center. Is this normal? I like to think it is the drive shafts (lots of grease around boots, but they are still intact). I just borrowed a 12 point 8mm to remove and inspect them. Could it be the rubber center clutch?... torque tube?... Mike
Old 07-29-2003, 07:26 PM
Dave951M's Avatar
Most likely the CV joints. The tranny does have a bit of side to side, that's normal. Also, don't ever jack up the car under the tranny, you could destroy the upper tranny mount or break the case. Use the jack points listed in the factory literature. Welcome to the group, these cars are like crack, if you aren't careful, money can disappear at a frightening rate.
Dave951M
86 951 Blitzwagen
82 931 Basket Case (for now)
Old 07-29-2003, 07:34 PM
SoCal Driver's Avatar
Clutch disk. Rubber center is sheared and the center is hitting the safety ears on the outter part. Most likely why the PO sold the car. Will not last much longer.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-29-2003, 10:39 PM
If SoCal is right, it sounds like it's time to upgrade to the spring center clutch.
Welcome to the board!
VT944
Brian
1985.5 944
Dodge Viper Blue on black/tan
white face gauges
throttle cam
short shift kit
Old 07-30-2003, 12:11 AM
MrPants's Avatar
#3 for the clutch
hope you either got time or money
84 944 Non Alcoholic
Old 07-30-2003, 01:04 AM
Dave951M's Avatar
Forgot about that monstrosity. Pull the starter and if you find rubber chunks, it could well be the clutch. While you've got the axles off for that job, why not r&r the cv joints as well. Welcome to the "while I'm in there" club
Dave951M
86 951 Blitzwagen
Old 07-30-2003, 04:57 AM
Thanks for all the good advice... I'll let you know what I find
Old 07-30-2003, 09:39 AM
