-   -   Annoying, but not aggrivating (yet) (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/121080-annoying-but-not-aggrivating-yet.html)
CJFusco 07-29-2003 08:01 AM
I've noticed that after starting my car and letting her warm up for a few minutes, she initially stumbles upon accellerating from a standstill. After driving for any more than a couple of minutes, the problem goes away... until she sits without being driven for over an hour or more.
Thoughts?
SoCal Driver 07-29-2003 08:07 AM
Fuel. Pressure, dampner, filter, pump, cat hair.
Macfreak007 07-29-2003 08:15 AM
mine always used to do that, never felt like paying to figure it out or fix it.
TCMdocs944 07-29-2003 08:25 AM
during the rebuild my ENGINE TEMP SENSOR at the front of the block, just under #1 injector, literally crumbled off in my hands. The wiring harness connection was fine but the plastic connection on the actual part was destroyed from the inside out.
I think it is responsible for the dme knowing if the engine is warmed up yet and it adjusted the mix accordingly.
It is very easy to get at and $28(napa) to replace.
TCMdocs944 07-29-2003 08:27 AM
BTW(i can't believe I now don't even flinch at paying $30 for a part half the size of my little finger!!!)
CJFusco 07-29-2003 09:15 AM
SoCal - in trying to sort out an apparent accelleration problem (part of me still thinks it's my worn clutch affecting my accelleration), I replaced the fuel filter, cleaned the air filter, replaced the spark plugs, tested the throttle switch with an ohmeter, tightened the throttle cable, and cleaned out the inside of the throttle body... I know it sounds like a lot to do without knowing what's really wrong, but I felt it needed to be done.
Someone suggested to me that the problem could be either the AFM sensor (which i still need to test) or the DME... if it is the DME, will getting Wilk's Power Prom solve the problem? (i was going to buy the Power Prom anyhow)
TCMdocs - how do i know if my Engine Temp Sensor is faulty?
Pike 07-29-2003 09:49 AM
_ If the problem did not go away and only happened at low RPM, I would guess that it was the injectors, but I don't really know.
CJFusco 07-29-2003 11:01 AM
why do you think it is the injectors?
ronin 07-29-2003 11:29 AM
it could be more than just the injector(s). start with the fuel system in geneeral and then go to the F/I system-electronics.
CJFusco 07-29-2003 11:50 AM
what is that supposed to mean?
ronin 07-29-2003 12:08 PM
check the fuel system in general, i.e. filter, fuel pump, lines, injectors etc. this will show whether you're getting proper fuel pressure. then move on to the rest of the fuel injection system IOW the electronics side, and check the throttle switch and air flow meter. also be sure to check for intake air vacuum leaks
CJFusco 07-29-2003 12:10 PM
1) how do i check the pressure, or that i need a new fuel pump or lines?
2) filter was just replaced a month ago
3) already checked the throttle switch
ronin 07-29-2003 12:26 PM
1) unfortunately I don't have the official shop manuals but you can check the fuel pump by removing the plug from the end of the fuel rail and connecting a fuel pressure gauge. Before you do that, you can 'drain' the fuel system by pulling the fuel pump fuse and letting the engine run until it quits. That way you won't get fuel all over.
Once you have the fuel pressure gauge in place, you can then test the system by running the fuel pump (withouth the engine running) by jumping two terminals in the air flow sensor connector plug. Unfortunately, since I don't have the manual, I can't tell you which terminals to jump and what pressures you're looking for.
At least this gives you a basic idea of how it's done. I'm going to see if I can come up with the specs but hopefully some of the other listers can help sooner. AFJuvat and SoCal, you guys listening? :)
TCMdocs944 07-29-2003 12:37 PM
To check the engine temp sensor I am sure you just check for ohms/no ohms both cold and in hot water. It only has two prongs on the plug, cold is usually in the closed position. This looks very similar to the thermo-fan switch only alot smaller and hooks to the dme.
The condition of mine was so poor that it couldn't even be tested(prongs ?rusted? off). It was significant enough that my next project will be to go through every sensor that the dme uses, pull the plug, clean it up, and plug back in.
Age/heat is unkind to plastic and rubber.
ronin 07-29-2003 12:37 PM
step two of the process would be to check the fuel system under idle. This is where I need to get the numbers for what pressures you're looking for. The first part is to check the pressure while the engine is running at idle. The second part is to disconnect the vaccum line to the intake manifold while the engine is till idling and then closingoff the vaccum hose. These two steps will give you the readings you need to see if the fuel system is performing properly. Now if I just had those numbers. ;)
ronin 07-29-2003 12:39 PM
Ditto on that, my car has about 146k on it but still runs really well. However, I do wonder how much better it would run if I did the same.
TCMdocs944 07-29-2003 12:48 PM
Ya know, I haven't even said it because CJf is an oldster around here but.
HEY CJ,
with the work you were doing to clean up the afm etc. did you accidentally pull loose a vacuum hose?
Didn't think so....
Just thought I would check.
97XRAY 07-29-2003 01:11 PM
Isn't the TPS often implicated in this type of problem, cold start, TPS isn't working... stumbles?
ronin 07-29-2003 01:14 PM
usually the first thing to look at but CJ already checked it
SoCal Driver 07-29-2003 03:55 PM
83 944 DME Testing Plan -- about 20 pages -- also included in the factory manuals. Gives all of the resistances and stuff. Also a XY cause and effect cart.
