Send a message via AIM to TheCooler
Clutch just went....
Well, I was going from 4th to 5th going on the highway when the car just revved all the way so i pulled over and tried to get in all the gears and all of them revved and it smelt like clutch bad. So i called the toe truck. Right now its sitting in my grandparents garage waiting to be worked on. Any tips on the clutch job? Anything I should do while im in there?
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 08-02-2003, 03:07 PM
I just started doing mine...an 87. She had rubber pieces sitting on the bottom. (where I pulled off the starter) So far I've removed the starter and the drive axles. There are lots of good posts here to help. I now have the confidence to do the job myself (mostly!) Good luck
'87 944 Maraschino Red Metallic Euro delivery...five speed
Old 08-02-2003, 05:19 PM
TSNAPCRACKLEPOP's Avatar
it would be unusual for the clutch to go shifting from 4 to 5, without some previous warning, such as slipping, or smelling. was there a clunkl of any kind??? do you abuse the clutch so you knew it was going?
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 08-02-2003, 05:43 PM
It was clunking ...I knew it was going ..just not then ..hah
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 08-03-2003, 07:28 PM
