1986 944 fuel pump - where is it?
And can I use it on a 1983 944? - Car will start and idle good, but only if the engine heat sensor switch wires are disconnected, but engine will not rev up. I have replaced the heat sensor switch - the one by #1 spark plug, and I have replaced the fuel pressure regulator. thanks to y'all.
Old 08-03-2003, 07:26 AM
SoCal Driver's Avatar
86 944 fule pump is under the plastic cover next to the fuel filter.
Same pump.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-03-2003, 11:07 PM
