Question hot air blowing
call me naive but i was wondering if anyone knew what is wrong with my 86 944n/a when it contiously blows hot air out of the vents even when the temp selector is on cold. what could be the problem any answer would be great
Old 07-24-2003, 09:22 PM
BlueQuestTSi's Avatar
Do a search on this forum, this has got to be the most oftenly asked question and is even in several FAQ's throughout the internet.
Jack
86 Red 951 - Turbo Twists, otherwise stock for now
83 Black 944 w/86 951 front end - still down and out, but coming back slowly.
02 Altima SE 3.5 - grocery go-getter
00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi
Old 07-25-2003, 06:15 AM
heat on
Dear 944 with heat,
I had heat on all the time in my '83 944, the problem was a broken end of a cable. That cable connects your temperture selecting slide in your console and the heater valve in your engine compartment. My cable was broken off on the engine side. A heater valve opens and closes to allow hot water/antifreeze from your engine into something called a heater core. With the valve open, hot engine coolant passes thru the heater core and warms up your incoming air. E-mail me if you want a procedure to reach down in the engine area and turn the valve off. tfranko29@pga.com
Good Luck,
Frank
Frank in Naples, FL
1972 911T
1983 944
Old 08-06-2003, 09:14 AM
SoCal Driver's Avatar
The later model 944's use a different heater system.
Above the gas pedel is a white plastic link. This either falls off or breaks.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-06-2003, 09:19 AM
