Unhappy automatic transmission flex plate failure
I resently had my 83 944 auto trans overhauled. Less tha 200 miles later the
trans would not shift properly. The transmission shop found the bushing in the torque converter broke loose and the flex
plate cracked 2/3 the way around the hub .
They sais the flex plate caused the converter to fail. A new flexplate a converter was installed at my expence. Less than 200 miles
later the flexplate again failed completely
while driving less than 10mph in a parking lot. The car was driven very easy, with no hotrodding after the trans overhaul. I feel either the input shaft in the trans or
the drive shaft is bent. However, after picking the car up after the trans overhaul I could hear what sounded like a loose muffler
bracket near the engine. I would very much like input from someone more knowledgeable
than myself as to the probable cause of the flex plate failure and the best way to identify the problem before taking it back to
the transmission shop where it is still under warranty. Any help would be greatly appreciated.
Gene
Old 04-11-2001, 02:44 PM
Post
Hi Gene,
I've seen an auto in a buddy's shop with that big rubber thing up where the clutch goes in a manual, and it was shot & messed up the bearings in torque tube. This might be your problem. My buddy's name is Manual Santana, & shop number is 864-229-9714 in SC.
He may have some advice.
With a manual trans, there is a spec for how far the shaft sticks out from the rear flange, 1/2" to 9/16" I think. There probably is a spec for autos & yours may not be correct.
drew1
[This message has been edited by drew1 (edited 04-13-2001).]
Old 04-11-2001, 06:17 PM
Lightbulb
Gene
Before editing, my previous reply had wrong phone number.
drew1
Old 04-13-2001, 09:39 AM
