windshied wipers problem
1986 944 Turbo -The wipers work fine on the medium and high speeds. On the low speed, they either do not work at all or they shudder across the windshield in slow motion. The intermittent setting works only occationally - mostly not at all. What the deal?
sounds like the relay, which controls all that stuff ... check on Ebay for a replacement.
E ------------------ Lock Stock '84 944 and two smokin' tires ... |
If the above suggestions did not work, you probably have a bad switch in the steering column....My last 944 didn't work at all on high speed...I changed the switch, and it worked like a champ...Cus
| All times are GMT -8. The time now is 06:43 AM. |
