How Many Here Are S2 Pilots?
If so, how do they compare to the 944 Turbo?
Is there any reliability difference between the two. I know they will each have their own issues, I was curious if there were any dual 944 owners that have lived with these beauties side by side. Thanks! |
vott does ziss do?
S2? sheep in wolf's clothing
![]() ![]() ![]() I can't speak for the S2 as I have not owned one but I have had my turbo for nine years now and love it!! the major difference is of course in the heads. other than that they are almost the same. not sure of the difference in maintenance costs but have a hunch that they would be very similar. I haven't heard of any major problems that S2s are faced with. the biggest thing about the turbo is that if the turbo goes out, it can be a bit pricey to replace. the turbos are rather durable however, and if cared for properly (proper cool-down time, regular oil changes), they should last a long time. either way, they are both very competent and solid, world-class cars. it just comes down to personal preference. some folks just don't care for the kick that a turbo provides when it spools up, and for the rest of us it's a rush that just can't be equaled.
I've got an S2 that sees regular track time (PCA DE's).
I can say that the S2 has some wonderful low-end torque that the turbos do not have. Stock for stock, the 951 vs. S2 would be a close match, depending on the track. Unfortunately for me, there aren't that many stock 951's on the track these days, so typically, the 951's I run with yield quicker lap times. :grr For autox, an S2 has an advantage over any 951 (stock or modified). Low end torque and no turbo lag means the S2 can be driven smoother and faster than a 951 on a tight cone-lined course. For the street, it's up to you which is better: the 951 is more of a street-light to street-light bullet (I am not advocating street racing, BTW), while the S2 is more of a grand-tourer on the highway. (Once you get up to speed, the turbo doesn't offer anything over the S2) Just my $0.42, -Z.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
I want one of each!
OK. Maybe two of each.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
The only maintenance item on the S2 above and beyond the 944 & 951 is the cam chain tensioner. Stay up to date with it ( and the other regular maintenance items) and the car will run forever. Ignore it and say hello to your newly maxed out credit card.
Pete 1989 944S2-Dove Blue Metallic 1985.5 944-Alpine White--sold My P-car Online Profile |
Custom User Title
I am under the impression that if your timing belt breaks on an S2, its twice the fun.
vott does ziss do?
hmmm, so now which is it? does it have a cam chain or a timing belt??
True, a broken belt on an S2 is expensive but the turbo never goes out :-) You have to be pretty bad to have a tbelt go on an S2, they are nice wide strong belts and dead easy to retension. And if you cannot manage to change the belt every 40k miles or so, and the tensioner pad every 100K, lease a new Toyota :-)
Having both a Turbo S and an S2, I can say they are both great! The turbo's lack of bottom end grunt and tall gears are irritating off the line and in traffic, but the turbo hit does impress. The S2 motor gets going early and really sings above 4k. It's a wonderful motor. I'd prefer slightly taller gears for the S2 and shorter for the Turbo. The S2 is much more of a good only car IMO. the Turbo is more likely to have annoyances (and much more so if modded.) There isn't much to mod on an S2 (at least not productively) so you end up with a reliable, fun car that just works. I bought the battered Turbo S to do a motor swap into my Cabrio, but I'm having so much fun with the Cabrio stock that I'm having second thoughts. It's a blast the way it is! -Joel.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
-Joel.
vott does ziss do?
I seeeeee. you learn something new everyday. I wonder if this was done to not have to redesign the entire drive system.
I don't think anyone has mentioned the fact that the S2 has a 3.0 liter engine. That is a freaking huge 4 cylinder!
The present: 83 944, 77 911S The past: 95 911, 67 912, 76 912E |
vott does ziss do?
yep, just think of it as half of a 6-liter V8. those are bigger pistons than the 350 LT1, or many other small blocks for that matter!
I'm not worthy, I'm not worthy! SWEET! I think I need me a 1991 S2.
Regarding the S2:
If the timing belt goes, you have a greater chance of bending more valves: there's 8 more than on the turbo. At $90.00 a pop for a valve, than can get pricey. If the cam chain goes, again, bent valves will probably occur. The head probably won't go (like on the 944S): they fixed some internals to prevent that catastrophic failure. -Z.
Oh, and one more thing: in 1991, they upgraded the rear spoiler to a raised one, like the 968's. Nice update, IMHO.
-Z.
Sweet!
Since I am in no hurry, and I have scads of time on my hands. I'm seriously considering getting one of these and completely going through it. I already have another car as a daily driver so that is a big relief there. Right now I'm on permanent disability because of a head injury so I went from being a numbers wiz in mortgage banking to having my kids count my change for me at the grocery store. It's not as bad as it seems, and the rest of the brain seems to work ok. ![]() I would like to just find a way to fill up my day but have something to show for it at the end. |
somone who's driven my s2, says that it's more controlable,
better gas millage turbo is not comfortable as a daily driver in traffic, as the gas is more of an on off switch
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
I concur, having driven both before purchasing my own, I decided that as a daily driver, the S2 is the better car, it is more balanced and more controllable. The turbos are more powerful, better for track days where you get long straights and you can make use of the forced induction.
Alain Prost (4x world F1 champ) claims to prefer NA engines for the simple reason that the low down grunt makes cornering faster on exit. Given that the S2 and the Turbo are pretty much the same apart from the airflow and gearing I would say it depends on how and where you drive as to which car suits you. I live in England, with lots of twisty roads so the S2 makes more sense for me but if you live in the Big Country, those long straight desert roads for example would not really benefit from better cornering ability... As any S2 driver will take great joy in reminding you though, straight roads are for fast cars, twisty ones are for fast drivers... ![]() Maybe I'm talking out of my ass, but there are plenty of arguements for both cars. Me I just think the "S2" on the back looks better than that awful squiggly writing the turbos are adorned with!
(x)'89 944 S2 Cabriolet (Guards Orange) : ( )'90 944 S2 (Maraschino Dead!) : ( )'89 Audi 90 Quattro 2.3 20V : ( )'92 Renault Clio 1.4 : * |
