paulc's Avatar
engine oil light on with swapped guage cluster
just swapped out my guage cluster with another used one(my tach was not working for ever).
tach now works, cleaned bulbs and reflectors............but my lower left ENGINE OIL light is on along with the large ! warning light.
is this warning me of an inadequate oil level or is it a faulty engine oil pressure sending unit? Do you think the two warning lights are related? What to check.
87na guards red(mine)
98 suburban(mine)
04 4Runner(wife's)
Old 08-09-2003, 01:45 PM
SoCal Driver's Avatar
The warning lights come on when grounded by the sensors. You could have a crossed connection somewhere.
Pull the wires on the oil pressure sender and see if the lights go out. Also check that the wires are on the correct connectors on the oil pressure sender. Think there is a dot of paint the same color as the wire for it on the sender.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-09-2003, 04:13 PM
paulc's Avatar
will do.
98 suburban(mine)
04 4Runner(wife's)
Old 08-09-2003, 04:16 PM
