Magnus_944's Avatar
Question Oil Filter Brand?
I'm going to change oil and filter soon and I wonder what brand of filter I should trust?
/Magnus
Old 04-21-2001, 09:44 AM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
Mahle
Old 04-21-2001, 09:56 AM
Post
I use the mahle also. Sometimes if I start to change oil and I'm out of filters I will go to autoZone and get one there. Its about $3 and the brand is Deutsch. Never had any problem with them but I try to keep a couple Mahles around. I really don't know if one is better than the other. I have used about 4 or 5 of the Deutsch brand but use Mahle most of the time.
My 944 na that I drive everyday has 198,000 miles and doesn't use any oil at all but I use synthetic oil.
[This message has been edited by T86951 (edited 04-21-2001).]
Old 04-21-2001, 11:54 AM
Post
Have you guys seen or used the new K&N oil filter? It costs a few bucks more, but seems to weigh nearly twice as much as the stock one. Apperently filters more that the stock one too.
Old 04-21-2001, 12:58 PM
Post
WIX, used to work there in Gastonia, NC before I went in Army. WIX makes all kinds of other brands, but QC specs are higher for WIX. Also has more filtering media, so more area for oil to get through & less pressure drop.
drew1
Old 04-21-2001, 01:38 PM
Magnus_944's Avatar
Post
Has anyone an opinion on MANN filters? The reason I'm asking is that the store I visited today had just switched from Mahle to MANN and claimed they are better, but I have seen some old test of oil filters and it didn't rank MANN very high.
Who makes the Porsche OE filter? Or maybe I should buy the filter at the local Porsche center... probably $$
/Magnus
Old 04-21-2001, 02:55 PM
85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
Post
i buy oem filters from the dealer, 12$ last time i got one a month or so ago, and they even look nice
Old 04-21-2001, 03:24 PM
Banned
Post
I use "Mahle" filters in our car's. Have never had a problem.
shaun... your ideas are sooo helpfull. Let's try having this post stay on subject.
Old 04-21-2001, 03:32 PM
Post
Mahle is the OEM supplier for Porsche filters. You can get them for $4 each at Paragon Products -- they're exactly the same as the $12 ones from the dealer, except they don't say 'Porsche' on them.
Old 04-21-2001, 08:34 PM
Post
Pelican Parts sells the Mahle for $8.30. I've seen parts stores in town sell a basic Fram for $15.00...just because it's for a Porsche. It's discrimination!
Old 04-21-2001, 11:47 PM
Post
I use Mahle...Check ebay...from time to time, there is a dutch auction for a case of 10 for $35.00....Do de math!...Dat's $3.50 fiddy a piece!....Cus
Old 04-21-2001, 11:58 PM
Post
I use FRAM but that was the OEM filter for the 912. I would go with Mahle as Porsche doesn't use cheap products so why use something they don't recommend.
Joshua Harrison
1968 912 Coupe
Old 04-22-2001, 01:13 PM
Blackfoot's Avatar
Post
mahle.
Old 04-22-2001, 01:16 PM
Mein Gott!
Panzer909's Avatar
Post
Mahle. Always used 'em, always will. If you want a case of 10 Mahle filters for $35 at any given time, go to www.rustyparts.net or call 800-741-5252. Rusty will hook you up. Good guy to talk to.
Old 04-23-2001, 05:43 AM
Obin Robinson's Avatar
Wink
i use several different ones:
Mobil 1 filters for the Scirocco 16V (because i put full synthetic Mobil 1 in it)
if i can't find a Mobil 1 i will get a K&N oil filter.
i use Deutsch or Fram extra gurad, depending on what is in stock and where i go. remember that i live in Ithaca: if it ain't a chevy cavalier... you gotta order parts from out of town.
obin
Old 04-23-2001, 08:00 AM
Magnus_944's Avatar
Thumbs up
Thanks for your replies! I bought a Mahle filter today.
And if Shaun has any oil related problems in the future, we all know why.
/Magnus
Old 04-23-2001, 08:33 AM
justin's Avatar
Post
I use Wix or Mahle
Drive it like you stole it........Justin
Old 04-23-2001, 08:50 AM
85944na's Avatar
Post
I use the Porsche one because everytime i change my oil I end up getting the filter last minute and the auto parts stores charge 16$ for a crappy filter so 12 for oem is a bargain. I really should order some mahle filters though.
Old 04-23-2001, 02:06 PM
In the Fires of Hell.....
kdjones2000's Avatar
Bringing this post way back from the dead.
My local shop recently switched from Mahle to Mann oil filters for some reason. Their claim was that Mann's were as good as or maybe even better than Mahle. I was wondering if anyone knows anything more about Mann, experiences etc.?
There is only one place where I can currently get oil filters for my car locally, and I am wondering if I should stick with Mann or have to order these things and have them mailed to me.
Thanks, Keith
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 09-26-2010, 12:53 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
brand name
Mann is OK, I prefer Mahle, but that is just an opinion. I buy them a few at a time and change the oil regularly. Tip: pre fill the new filter with oil using a magnet to lift the little plate and then pop it in the freezer for a bit. The oil thickens enough that you can spin it on quickly without a mess. prime the system by pouring a little oil into the block and diconnect the plug wire so that you can crank the engine to get pressure. THEN start the engine without that annoying clatter for a sec as the oil fills the passages and pressure comes up.
Mahle, Mann, WIX, in that order IMHO. Reasonable minds may differ.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 09-26-2010, 01:13 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
