Kirby2's Avatar
cutting out after 3000 rpm
My '86 N/A Cuts out when I accelerate. Runs smooth otherwise. It just seems to stick.
Recently replaced AFM and TPS, good ignition, wires and plugs.
Anybody had this happen ??
Old 08-05-2003, 06:44 AM
Does is do it if you just rev the engine or must it be under load where it need a lot of fuel flow?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-05-2003, 08:07 AM
Kirby2's Avatar
Under load (in gear).
Also first start in the morning is ROUGH, then smooths out and subsequent starts are easy and smooth.
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 08-05-2003, 08:18 AM
Wonder if it is starving for fuel.....When did you last change your fuel filter? Has it done it with more than one tankful of gas (implying bad gas here)? You might check the connections at the fuel pump. They could be corroded and causing intermittent contact. These are some of the simple and cheap things to look at first.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-05-2003, 11:14 AM
were are the fuel filters on the 86 turbos? are they in the same place as the na's?
scott
86 944 turbo(weekend toy)
97 dodge stratus(wifes car)
83 audi 4000s(work car,everyday car)
Old 08-05-2003, 11:25 AM
Kirby2's Avatar
Changing out Fuel regulator ($60)and new fuel filter($30).
86 White 951 - His
98 C-4 Sons
Old 08-05-2003, 12:07 PM
On an 86 turbo, the fuel filter is in the rear. I imagine the NA's are located in the same area. When dry, a fuel filter is easy to blow through if it is ok.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-05-2003, 12:41 PM
Kirby2's Avatar
FUEL FILTER IS LOCATED IN PASENGER SIDE REAR WHEEL WELL...PROBABLY TIME TO CHANGE ANY WAY.
86 White 951 - His
98 C-4 Sons
Old 08-05-2003, 01:25 PM
Kirby2's Avatar
I hate it when people have problems and don't get back with the solutions, so here goes. Swaped out all the fuel gear, AFM,TPS,Fuel filter, DME, FP Regulator, ends up that cylinders 2 and 3 were starving because of dirty injectors.
Techroline to the rescue! I hear that the Red Line cleaner is better though, I may run a second tank of the Red line just for good measure.
86 White 951 - His
98 C-4 Sons
Old 08-14-2003, 08:44 AM
