paulc's Avatar
question about this board
can't remember but, when you first sign up on this board and register, do you have to post a new topic or question first for your information to be accepted? got someone who's having problems; after registering and logging on he can't reply to someone's post.
87na guards red(mine)
98 suburban(mine)
04 4Runner(wife's)
Old 08-12-2003, 04:52 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
From what I can remember you don't, unless it's changed. They haven't gotten an email?
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 08-12-2003, 05:03 PM
paulc's Avatar
yes, they did....i believe he's doing everything right. each time he goes to reply to someone it asks him to sign in, which he does, then it says hello, you are signed in(blah, blah, blah) and then bounces him right back to the error message saying he is not signed in.
98 suburban(mine)
04 4Runner(wife's)
Old 08-12-2003, 05:07 PM
pearldrum's Avatar
I think you have to respond to the email by going to a link to verify that the email was sent to the right person. Did they do that?
Old 08-12-2003, 05:08 PM
dj_yen's Avatar
sounds like he has his web browser set to refuse most to all cookies
what browser is he using? and what version?
Old 08-12-2003, 05:09 PM
paulc's Avatar
i'm not sure but they are reading these posts most likely. i guess they will need to change their browser under the Tools option if it is Internet Explorer right?
98 suburban(mine)
04 4Runner(wife's)
Old 08-12-2003, 05:27 PM
dj_yen's Avatar
one should always be able to read a post regardless of their cookie settings
if you have the latest version of IE then you goto Tools, Internet Options, then Privacy
set Privacy to the lowest and try then
if it works, i would raise it incrementally
it should work all the way up to medium-high (if you have an older version, medium-high may not be available and only medium)
Old 08-12-2003, 05:31 PM
paulc's Avatar
any other possible explanations? seems kind of weird that it accepts their log-in attempt and then bumps them back to the log-in page. just below where i am typing it says Forum Rules....and it says something about HTML being ON.........could his be OFF?
98 suburban(mine)
04 4Runner(wife's)
Old 08-12-2003, 06:17 PM
rbt944's Avatar
Does he open the page from the link that was sent to his email?? If so just close it and open another page and access the boards that way. I used to have a similar problem. Every time I would try and respond on the page that I opened with the e-mail link i would get the same symptoms you are discribing.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 08-12-2003, 07:26 PM
set everything to defaults...reboot
of course if he ever said he had a KIA once...anywhere on the internet...well, he is stuffed and will have to assume I new identity
Tom
Early '85 944
Old 08-12-2003, 08:11 PM
TSNAPCRACKLEPOP's Avatar
i think he needs to start by changing the timing belt.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 08-13-2003, 07:05 AM
dj_yen's Avatar
have you tried what i suggested?
when you log-in you are obviously sending data to pelican stating that you have a proper username and pass. after this occurs, Pelican sends you a cookie (packet of data) that is saved in your computer so that everytime you do something within pelican forum that requires login, this cookie tells pelican that you are a member and already logged-in. now if your browser is set to reject most/all cookies then this packet of data (cookie) is never saved on your comp therefore wheneve you request to do something on pelican that requires login information (such as posting in the forum) you are asked to login again. that is why one can read posts but not reply or compose one of your own cause reading posts requires no login information. that is also why if this cookie is accepted (like on your comp and mine), you are never prompted to login again.
Old 08-13-2003, 11:44 AM
paulc's Avatar
not sure if they have done anything, but like I said........they are most likely reading these posts about this...(cuz i dun told 'em to!)
hope to get it straight soon. thanks for the help, will let you know.
98 suburban(mine)
04 4Runner(wife's)
Old 08-13-2003, 01:22 PM
BlueQuestTSi's Avatar
Might also be a ground problem. Just don't drop that bolt down in the flywheel's TDC hole, that would cause a serious Internet Explorer shutdown.
Jack
86 Red 951 - Turbo Twists, otherwise stock for now
83 Black 944 w/86 951 front end - still down and out, but coming back slowly.
02 Altima SE 3.5 - grocery go-getter
00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi
Old 08-14-2003, 06:14 AM
