-   -   Window rattling (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/123051-window-rattling.html)
CJFusco 08-12-2003 07:37 AM
Window rattling
When I closed my driver's side door with the window open yesterday, it made an irritating rattle. I stuck my finger down the window frame, and sure enough the window was loose and could move about 1/2 inch back and forth. When the window is up all the way there is no problem, and when it is partially up there is less rattling but it is still there.
Please tell me this is as easy as "take the panel off and tighten this bolt" !
SoCal Driver 08-12-2003 07:48 AM
Could be that easy. The rear track could be loose. Or just needs the felt window guides replaced. Or both.
Macfreak007 08-12-2003 02:15 PM
ok, I had the exact same problem, take the panel off and you should probabyl find the felt window holder in the bottom of the dorr, it has fallen off, and if you re glue it in the window rail it should be just fine.
paulc 08-12-2003 02:36 PM
try a pacifier instead.
