daveimme's Avatar
Send a message via Yahoo to daveimme
6 blade fans.....
I found 2-6 blade fans from a parts place for $25/each. Is this a good price? Can one be had cheaper since I don't know what to expect for this. Guy will throw in a hood release cable for $15 if I get two fans.....
83 944 N/A 5 sp. (mine)
90 Acura Integra auto (sons)
2000 Honda Odyssey EX auto (wife)
83 Suzuki LT 125 (4 wheeler) (wife)
92 Honda XR 80 (son)
97 Honda CR 125R (son)
98 Honda CR250R (MINE)
2000 Kawasaki KX 65 (son)
2003 Honda XR 50 (Son and daughter)
Old 08-12-2003, 01:59 PM
SoCal Driver's Avatar
Make sure they run. Better yet if in the shroud and with the wiring!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-12-2003, 02:19 PM
daveimme's Avatar
Just the fans, NOT the motor.....they should fit on mine, right??
Old 08-12-2003, 02:32 PM
NO! Have to have the motors and the blades as one unit.
Old 08-12-2003, 04:18 PM
daveimme's Avatar
I see... the ones with a fan are $75. Guess I will keep looking then. Thanks for the heads up, that 'exclamation point' made its way!
Old 08-13-2003, 05:31 AM
bertman's Avatar
Just my $.02 worth... I think you'll find that the six blade fans are a great upgrade to the early 944. Your car should run cooler and the fans are noticeably quieter than the early units.
bertman
84 944 Original Owner
65 Plymouth Satellite
08 Mercedes-Benz E 350 Sport
Old 08-13-2003, 05:46 AM
Seen complete fan assemblies for $50 on eBay. Try to get then with the wiring harness cut off just at or past the temp sensor. By the way the post 85.5 use a three pin temp switch on the radiator. Two stage activation.
Old 08-13-2003, 07:50 AM
