CSU944's Avatar
Question Cam sprocket woes....
Should my camshaft sprocket (83 944) simply come off with a puller, or is there some trick to this? It won't budge...
Thanks in advance,
Tom
Old 08-15-2003, 01:07 PM
Dave951M's Avatar
Did you take the bolt out of the center? There is also a sleeve that is shaped similar to a nut that slips on, it has to come off as well. The sprocket is keyed on. It may just need a little persuasion if the key way has corroded a bit. Use some PB Blast and let it soak a while and try again.
Dave951M
86 951 Blitzwagen
82 931 Basket Case (for now)
Old 08-15-2003, 01:38 PM
ae1969's Avatar
Send a message via ICQ to ae1969
When you finally strip out the bolt holding the sprocket....
You can drill it out.......
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-15-2003, 02:18 PM
Terry Richards's Avatar
The bolt is a 12 pt bolt or a triple square. Check with a parts store, from what I understand they carry the tool. Make sure the tool is fully seated befor turning. Also you will need to hold the cam with I think a 32 mm wrench.
Terry R.
1988 944 NA AT Alpine White
1987 944 NA AT Stone Grey
1987 944 NA 5 Speed Stone Grey
1987 944 S 5 Speed Triple Black
Old 08-15-2003, 07:33 PM
CSU944's Avatar
Got it out...turns out that the cam-rotor adapter was stuck in there, and I couldn't even see the cam bolt. And Autozone carries the tool, it comes in a set that will also fit the flywheel bolts if anybody's interested. Thanks for all your help.
Old 08-15-2003, 10:15 PM
