-   -   tune up (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12356-tune-up.html)
pschaars951 04-26-2001 01:30 PM
tune up
I was just wondering what all a tune up is.
I took off my distibutor cap to more easily access the thermastat and noticed that it was in pretty bad shape along with the rotor. Earlier I had noticed that the airfilter was pretty dirty and could use a change. The belts are all pretty new and are in good shape. but what else is part of a tune-up? do you need to change the fuel filter?
also how often should you do a tune-up... my therory has always been whenever something doesnt look to be in good condition anymore, but maybe i should be replacing things right before they dont look good anymore.
-pete
Lawrence Coppari 04-26-2001 02:31 PM
<font face="Verdana, Arial" size="2">Originally posted by pschaars951:
-pete
</font>
Why did you take off the distributor to access the thermostat?
pschaars951 04-26-2001 02:38 PM
i just took the cap off because it was just sortof in the way to get to the thermostat from the top (i have a 87 NA by the way) it wasnt necsesary to do, but i figured 5 wires and two screws to make looking at what i am doing a bit easier wasnt a bad trade off
-pete
floridaporsche 04-27-2001 06:52 AM
I recommend replacing the dis cap, plug wires, plugs, fuel filter, coil, air filter, and DME(fuel pump) relay.
