susp bushings
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_suspen_pg6.htm
what is the difference between pn#477-411-053G and pn#477-411-053J except the 3mm difference?
i would assume the 23mm bushing would be better to get?
can any of the 944T/S bushings be used in place of the standard 944's?
im replacing all of the bushings front and rear. is there anything else that wears out easily, similar to the bushings, that i should replace while im at it? (other than shocks/springs obviously)
Old 09-22-2003, 11:25 AM
Send a message via ICQ to interglossa
I believe it depends on the size of your sway bar. There are different thicknesses for different cars, so you basically have to measure it.
My '83 Sets me free!
Old 09-22-2003, 12:57 PM
