Crippler's Avatar
Dyno Results
Well I got the Callaway dynoed today. I was running about 13lbs of boost and only hit 192whp and 202ft'lbs. About the same as a stock 951. I was also running pig rich and have a pretty dead turbo. Also had too much timing retard, however I learned very much on what needs to be done. After some more tuning and rebuilding the turbo i hope to hit around 250whp or more. I also want to get rid of the stock air box and get a descent exhaust made up. anyways I will post the graph and the video later this week.
1984 - Porsche 944
1994 Grand Cherokee
6inch Lift, 33" TSL'S
Old 08-17-2003, 02:56 PM
PorscheG96's Avatar
Send a message via AIM to PorscheG96
Cool, that's a start.
Old 08-17-2003, 04:51 PM
BlueQuestTSi's Avatar
Running the stock exhaust? Ouch, there's your biggest problem
Get a nice 2.5" or 3" mandrel bent system under there, a straight through muffler and a high flow cat, and you'll probably gain 20hp to the ground from that alone(much quicker spool up). Also getting rid of the stock air box will allow for a little quicker response from the turbo.
Advancing your timing could of helped somewhat on your richness problem, and should of shown up as a few more ponies on the dyno. They didn't play with your timing?
Jack
86 Red 951 - Turbo Twists, otherwise stock for now
83 Black 944 w/86 951 front end - still down and out, but coming back slowly.
02 Altima SE 3.5 - grocery go-getter
00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi
Old 08-18-2003, 06:44 AM
how much boost can stock turbos handle?
and is 13psi stock boost?
Banana Boat with Boost
Old 08-18-2003, 09:30 AM
ae1969's Avatar
Send a message via ICQ to ae1969
You will definitely see an improvement with a better exhaust....
You should be pretty close to hitting the 250rwhp once you have worked through all the tuning....
As I recall Mark was running 15 psi....... he ran 18 psi but the turbo ran out of breath in the high rpms.....
At what rpms did you hit those numbers?
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-18-2003, 11:19 AM
Crippler's Avatar
Good news my turbo rebuild kit showed up today.
The exhaust isn't stock, The cat is hollow and I have a straight through muffler, but is all stock diameter. I plan on getting a 3in system made next spring, however there is no where around here that does mandrel bends
AE: I hit peak power at about 4700rpm and torque at about 5200rpm. My low end power was killed by my bad turbo, wasn't spooling fast
1984 - Porsche 944
1994 Grand Cherokee
Old 08-18-2003, 12:18 PM
