Send a message via Yahoo to Cebu
Oil Press Indication
86 944na..Ignition "off" gage reads Zero "0"..Ignition "On", gage reads 3.5 and no Idiot Light. Start Engine, gage reads 5 (pegged) no tapping or unusal engine noise. Leads to Oil Pressure Sender are secure. I am inclined toward a bad Oil Pressure Sending Unit. I would be greatful for your imput.
Old 08-16-2003, 01:07 PM
SoCal Driver's Avatar
That's where I would start. But it could be the gauge.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-16-2003, 04:08 PM
Replaced Sending Unit, high oil pressure indication remains. Ignition off, indicator at zero. Ignition "on", indicator pegs at 5-bars with idiot light on. After engine start, idiot light goes out, indicator remains pegged at 5-bars regardless of eng temp or RPM. Changed oil and filter , no change. No unusual engine noises or tapping.
Old 08-17-2003, 12:34 PM
Oil pressure sending unit connections swapped with no effect on pegging indicator
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 08-17-2003, 12:35 PM
Was this a new sending unit?
Old 08-17-2003, 01:57 PM
New sending unit $59.95 worth
Old 08-17-2003, 04:12 PM
Eeek!
Do you have an ohm meter?
Per factory workshop manuals:
Post 85.1 (85.5)
1 bar = 29.6 ohms
2 bar = 65.3 ohms
3 bar = 98.9 ohms
4 bar = 133.6 ohms
5 bar = 184.0 ohms
Pre 85.5
0 bar = 10.0
3 bar = 116.0
5 bar = 184.0
So there is a difference between the oil senders too...
But! It's the same part number for 83 through 88 928 606 203 01.
Figure that out.
Old 08-17-2003, 09:33 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
*raises hand* Done! It makes sense to me. Try taking out your Oil Pressure relief valve, seeing if it's scored or sumpin.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-18-2003, 03:51 AM
An 86 should have the encapulated oil pressure regulator. Can get dirty but doesn't score the sides of the block and hang up. Does have o-rings that quit o-ringing though.
Old 08-18-2003, 07:58 AM
bump for more imputs
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 08-18-2003, 05:14 PM
BlueQuestTSi's Avatar
Take Hugh's figures that he posted, and use a volt/ohm meter on the wires to the gauge. See what reading you get there, now compare them to readings at the sender itself. Could be an issue between the sender, DME and gauge(if the DME relays that info that is...)
I'd of liked to of said it's a bad gauge ground, but those usually make the gauge read on the low side, not the high side.
Jack
86 Red 951 - Turbo Twists, otherwise stock for now
83 Black 944 w/86 951 front end - still down and out, but coming back slowly.
02 Altima SE 3.5 - grocery go-getter
00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi
Old 08-18-2003, 05:32 PM
Yes check the sender first with out the gauge connected. One of the terminals to the ohm meter the other lead of the ohm meter to the engine ground.
You have cleaned the engine to chassis to battery grounds? Right??
Old 08-19-2003, 07:57 AM
