thamlin000's Avatar
Car won't start
Yesterday at lunch my 944 wouldn't start. The battery was dead. I didn't leave the lights on so I figured since it was an old battery (4 years old), all I needed to do was replace it. I got a new one, put it in and everything was fine.
Until this morning and now my car won't start. Dead battery. It drove fine all the way home from work yesterday.
I replaced the alternator about three years ago with a rebuilt unit. I couldn't be the alternator could it?
This really sucks, I'm moving 200 mi on Saturday and this is my only car. The Z is already at my new place.
The tow guy is on his way to jump start it or tow it.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 08-21-2003, 06:13 AM
thamlin000's Avatar
ps-The charge light on my gauges had been faintly glowing before I replaced the battery. I could only see it at night and after I replacd the battery, I didn't drive at night so I couldn't see it it was still glowing.
Old 08-21-2003, 06:16 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Man, I know how you feel, I just moved 250 mi. Did it all myself via U-Haul. Me, the wife, her dad, and her g-ma from L.A. to Fresno. 3 br house fuull of CRAP. I don't envy you.
On to topic: I assume that you've checked your alt. belt tension. My suggestion is this: if you don't have a multi meter, buy one. It's well worth it. It would be a simple matter to see if your alt is charging, or a bunk batt (seldom happens, but it happens) or a bad ground (the first thing I would suspect). Does your engine see a lot of water? do you have an oil leak that coats your alt? Check the 9 pin connector right above your brake booster. any burnt pins? burnt fuses?trouble shoot from the batt. onward. Clean those grounds.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-21-2003, 06:45 AM
thamlin000's Avatar
Problem solved. The driver side fan runs continuously even when the car is off and cooled down. I guess it need a thermoswitch.
Todd,
Thanks for the suggestions. I'm moving from a temporary (summer) job back to school 200 mi away. All the stuff I have will cram into the 944. Gotta love a car that hauls and also hauls.
Old 08-21-2003, 10:15 AM
SoCal Driver's Avatar
The fan temperture switch and the electric antennas are the most likely culprits for battery drain.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-21-2003, 10:23 AM
thamlin000's Avatar
Will a new thermoswitch fix my continuous running fan problem? The fan keeps going and drains my battery after the car is shut off. I just replaced the thermoswitch one year ago.
Old 08-22-2003, 01:24 PM
Custom User Title
rammstein's Avatar
Once you get it charged, I guess you could disconnect the battery each time you stop, until you can fix it, if you gotta move before you can get to it.
Old 08-22-2003, 01:58 PM
Might also be the AC relay as this too controls one fan.
Disconnect the battery when you park. Worry about it later.
Old 08-22-2003, 02:07 PM
thamlin000's Avatar
For now, after every drive, I have been disconnecting the battery. I'm going to buy a thermoswitch. And if that doesn't work, I'll get an a/c relay.
Thanks for the input.
Old 08-22-2003, 04:24 PM
