-   -   A/C electrical problem (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12431-c-electrical-problem.html)
Ehab 05-02-2001 10:05 AM
Hey all, today was a hot day in Boston. After using my AC for 10 minutes, the air blower fan stopped but everything else kept going. Fuse 6 was busted, so I replaced it, then as soon as I turn the AC back on, it blows again. This indicates that something else is shorting the circuit as soon as I turn the AC on ... anyone with previous experience? I need to know what is the most probable culprit (which part is burned out)
Thanks.
Lock Stock '84 944 and two smokin' tires ...
Mrmerlin 05-02-2001 02:44 PM
<font face="Verdana, Arial" size="2">Originally posted by Ehab:
Thanks.
</font>
First question is the fuse that you replaced it with the correct one if so then there is a heavy draw on that system if it keeps b;lowin, find the relay that runs the A/C and remove it clean the contacts use some dielectric grease on the fuse and relay connections..Let me know if this helps.....Stan
Porsche 951 Fanatic 05-02-2001 05:05 PM
Make sure there is nothing stuck in your fan! if its got something in there since it cannot spin it will blow the fuse http://www.pelicanparts.com/ultimate/wink.gif good luck
Ehab 05-02-2001 09:02 PM
I'm so glad that this didn't take long to fix. After redrawing the circuit from the Haynes Manual, I found out that the only thing that could short things out is the 'evaporator fan', which I think is the same as the coolant fan.
To my luck, I found out that relay III and relay VI are the same, where the III is the AC relay, and VI is the rear window defogger.
I switched the two relays, and voila ... it worked again, so obviously, the AC was shorting the circuit. I opened it, and the connection was bent and hitting the ground ... so it was the problem, I bent it back, and now it works again, so I put it back for relay VI, for the rear defogger (which I don't really use that much)
Thanks all for the comments and help.
Ehab
