unluckylow's Avatar
starting funny
Hey guys got one more guestion. This happens very rarely Ill drive my 968 around town and then stop for a wile go out and try to start it and it just turns over maybe starts for a second and dies takes a few minutes and then it starts, also only one time wile I was driving did it actually die, it didnt just cut off it struggled to keep running and died. I pulled over and turned it over for about 15 seconds and it started. Im not sure where to look, could it be the fuel pump or the fuel pump relay. Is there any way to test either of these to, if not one of these what might it be. thank you
Old 08-26-2003, 09:38 AM
SoCal Driver's Avatar
First thing to check is the DME relay. The contact points wear out and this can cause the fuel pump to quite working now and then. Buy a new one and replace yours. If this doesn't fix it then it's diagnosis time.
P.S. Most of us have a spare DME relay as this is the part that fails the most on the electronic injection system. My spare DME relay is in the glove box next to the annoying buzzer I pulled out 19 years ago.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-26-2003, 10:03 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Sounds like a loose connection.
Check the sensor cennectors on the firewall at the rear of the motor. these are for the referance and tdc sensors and if loose will exhibit this same phenomenon.
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 08-26-2003, 11:48 AM
adrian jaye's Avatar
I had a similar problem,
chenge out the DME for sure
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 08-27-2003, 06:30 AM
