-   -   Noise that goes tink (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12527-noise-goes-tink.html)
Mac 05-10-2001 05:01 PM
Before I just start replacing parts , did anyone have this noise ? The sound seems to be coming from the rear left wheel , a high freq. tink only when you load or unload the rear end . It will do it only once in each direction of load . I have checked the shock , CV joints , lugs , 32mm axle nut and brakes . I can make hard left or right turns without a sound . My 86' 951 has seen alot of track time (Mid Ohio , Glenn , Poccono ), any ideas , thanks .
Rollins 05-10-2001 05:07 PM
Is your parking brake engaged when you hear it?
Mac 05-10-2001 06:02 PM
The parking brake was something I didn't think about , but with on or off same, same.
