how is the speedo sensor to be tested?
I pulled the speedo apart and the gears are intact. How do you check the speedo sensor ( on the transmission)? What kind of voltage if any will there be? I tried to use a multimeter but couldn't get any numbers.
'87 944 Maraschino Red Metallic Euro delivery...five speed |
Should be sending out pulses. Have to search the past messages here and on Rennlist.com for the info. I'll check the WSM's to see if they have the info. May take an o-silly-scope to see them.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Thanks again. I'm not givin' up!
It uses pulses off of magnetic inserts off of the ring gear for speed.
What symptoms are you seeing? AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
I have a non functioning speedo and odometer. The odometer gear is intact and spins freely.
