-   -   A-C fails on 928GT (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12549-c-fails-928gt.html)
diskjoncter 05-12-2001 03:33 AM
A-C fails on 928GT
Hi all,
I'm just a new owner of this car and I would like to know if someone have the electric schematic of the AC system? I'm waiting the workshop manual but it's so long... and it's so hot!
Thanks in advance for info.
lm6y 05-12-2001 06:17 AM
Did you try to jumper the low pressure switch? I'm not sure where it is on a 928, but it should be by the receiver-drier. The switch is a two-prong electrical connection that is screwed into an A/C line. When you find it, jumper the two wires, and turn on the A/C. If the compressor clutch kicks in, you are low on freon.
Hope it helps
