jwolk1's Avatar
Offset Gurus - Boxster Rims on a 1986 944 Turbo - Please Help
I have searched and can't easily determine the answer to this, so I am asking for assistance. I have a 86 951 with early stock (23.3) offset - takes 16x7 in front and 16x8 in rear. I have the opportunity to purchase 2000 boxster rims with the following specs - 16 x 6 in front (50 mm offset) and 16 x7 (40 mm offset). Will they fit? Does anyone have pictures of this rim on a 944? Thanks -
Jeremy
Jeremy
2005 Cayenne S
2001 996
1986 951
Old 09-02-2003, 12:11 PM
Nabeel's Avatar
Send a message via AIM to Nabeel
I'm guessing these are the split-spoke base-style Boxster rim? I definately know that there have been pics of 944s with those rims posted here on this board in the past. I'm sorry I don't have any pictures fo these rims myself, the best advice I could give ya is to try searching through the archives some more to see if the pictures are still up.
'85.5 944
Kalahari Beige/Brown
5-speed
76K miles
color-matched fuchs
SOLD
Old 09-02-2003, 01:52 PM
They must be great looking wheels !!! Installing narrower wheels will down grade the handling of the car.
Mark
'86 944NA
Old 09-02-2003, 02:08 PM
They will fit if you install spacers and longer studs. Afer which you can use any early or late-offset wheels you want on our car. Procedure in the 944 Wheels FAQ section o fmy 951 RacerX website
Old 09-03-2003, 10:42 AM
spacers will run you between 85.00 and 139 ea for diff styles.
later
jeff
Old 09-06-2003, 05:29 AM
