time to replace the water pump
Can someone help me find the procedures to replace the water pump. It let go today and there was coolant leaking from the belt cover.
I have the cover off and i think i have to remove all of the belts. the timing belt( one side of teeth ) is really loose, the ballancing belts are good and tight. I need some help with this and would appreciate any help possible. If anyone in the chicago area mainly great lakes or southern wisconsin could help it would be great. i found the new pump for a reasonable price but have to wait till i get paid to get it. I am good with figuring things out but i need some where to start. thanks jeff |
Do not even start working on this job without a workshop manual, you should also have the Porsche Parts and Technical Information book.
There are a couple of web sites dedicated to 944 repairs, use Google to find them. You will need: Water pump, use the updated type Timing belt Balance shaft belt Alternator belt Power steering belt Water pump mounting kit (thermostat, bolts, gasket etc) Update kit for timing belt guide rail and roller All of the tensioners. If the front seals are leaking: Front seal kit Oil pump drive (engine number specific) and o-ring Balance shaft seal sleeves Crank seal (engine number specific) . It's vital that the crank pulley bolt is tightened to the correct torque. If you are changing the cam seal, always replace the cam seal sleeve and the two o-rings in the cam bearing housing. Retension the belts after 2000-2500 miles and then every 15,000 after that. Rotate the crank two revs after every timing belt adjustment and the check the tension. All of the parts are available from Pelican.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
So basically im screwed for now because this is gonna be a tough job and i dont have the tensionor tool along with the locking tools.
The water pump wants to turn but i cant do it by hand it wint spin. well I guess since she is dead this is a good time to take the time and learn how to do this. time for research. later jeff |
Not to mention that you have a 50/50 chance that one of the studs will break off in the block when you go to remove the pump. This requires extraction, and some times drilling and a helicoil.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Reading the post again, it appears that the timing belt is extremely loose. Whether this is because of where the engine stopped or is when the pump failed the belt stripped (= bent valves) you also need to carefully investigate.
Scott's right about the broken studs, spray them with penetrating oil right now, and keep on doing that so when you actually get round to doing the work the studs/bolts should come out.
Jeff, While the water pump replacement seems daunting it can be accomplished with a strong dose of perseverance.
Yes you do need to have decent manuals or printed instructions to catch all of the little nuances and assure a properly complete job. I suggest www.clarks-garage.com as a start. Also get a Haynes 944 manual. The actual factory manuals can be found on eBay as PDF's. If you want to send me a PM I'll give you my e-mail address so you can ask questions directly.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
