i was just wondering, what is the size of the gas tank in a 88 924S? the haynes manual for the 944 says 20gal. but everytime i fill up when the guage is past the last mark and the gas light is on it only fills up to slightly under 15 gal.???
thx
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
I've only driven my 83 dry once. Then I only put ten gallons in it as that was all the cash I had. Yes I did make the service station just off of the freeway -- at an idle. Not enought fuel to properly pressurize the rail.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
The owners manual for my 87 924S claims a 17 gal tank and that the warning light goes on when it is down to 2.7 gal.
I haven't run it dry but I have put 15+ gal in it after driving 30+ miles after the warning light went on. My guess is that you are seeing normal behavior for a 17 gal tank.
'87 924S 5sp Slowly recovering from a warped head |
the manual says 80 liter including 8 of reserve...let me convert:
21 gal,and about 2.1 is reserve. At least the manual state that...
--------------------------------------------- 85´5 951 |
