dj_yen's Avatar
dash covers
anybody know the quality and the reputation of this dash cover?
http://www.coverlaymfg.com/E_Store/Dash_Covers/Foreign/Porsche/
anybody have any other suggestions?
any help would be appreciated
Old 09-06-2003, 09:46 AM
entertaining the idea
UconnTim97's Avatar
Mine looks great in the cold, and shade. Once the sun hits it, it warps around the defroster vents. I am still trying to remedy that.
If they covered the useless center speaker, this problem probably wouldn't occur.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 09-06-2003, 08:22 PM
Coverlay dash cover
My experience with this dash cover is similar - mine too has warped a bit around the defrost vents. On the plus side, it still looks better than the shattered piece of eye-rot it covers.
I also had some difficulty getting it to adhere to the dash surface using their supplied silicon-based approach (as the contraction/expansion rates of dash vs. the cover materials interfere a bit).
So, for my part, I used a combination of lots of velcro strips (purchased from the local sewing supplies store) and two screws (placed at the 'ends' of the coverlay where the doors cover them when closed). This combination provides the right amount of 'stick' (i.e. the cover stays nicely in place) while eliminating negative effects of the differing expansion/contraction rates.
Regards,
DL
84 944 5spd
Maint. & Fixes made thanks to the help received on this board:
Rear Hatch Pins, Oil Change, Dash Cover Installation, New Rear Seat, New O2 Sensor, New Ignition Switch, New Fuel Pump Relay, Rear Light Assembly Reseal, Instrument Panel Short Circuit, New Speedo Cable, New Timing belts and Starter.
Old 09-07-2003, 02:26 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
Mine looks really good except between the windshield and the center speaker it has lifted about an inch.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 09-07-2003, 02:32 PM
I have the behind-the-center-speaker arch as well. And it won't sit down on the corners. If I can figure out how to get the cover and the silicone off, I'm going with a dash mat. Can't be worse than the other alternatives.
'87 924S , sold.
'99 Subaru O/B, 62K on first timing belt. Could have gone another 40K.
Old 09-07-2003, 03:09 PM
dj_yen's Avatar
can anyone suggest a place to purchase carpet covers?
Old 09-08-2003, 07:02 PM
Roger Hall's Avatar
The coverlay will warp I hate mine. Doesn't Pelican sell dash covers?
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 09-08-2003, 07:41 PM
Alternatives: http://www.weissach.net/924-944-968_Suppliers.html#DashCovers
Karl.
Previously: 1991 944 S2
Currently: Something from München...
Old 09-08-2003, 08:22 PM
Send a message via ICQ to interglossa
Funny... coverlay guarantees no warpage.
too bad i can't find the stupid receipt
My '83 Sets me free!
Old 09-08-2003, 11:04 PM
dj_yen's Avatar
i would suggest that you call them up and ask them for a copy of your invoice for tax purposes.
then after you receive the invoice, then contest the guarantee
Old 09-09-2003, 10:01 AM
dj_yen's Avatar
anybody know of a site with pics of carpet covers?
i know pelican sells them but no pics
Old 09-09-2003, 10:02 AM
I'm off the hook.....
I love my Coverlay. I ALWAYS use a foil windsheild / heat sheild. The windows are darkly tinted, and the car sits in the sun a lot, even in Vegas. I know the inside temps go crazy, but it seems that with the foil sheilds, the direct sun never gets to the cover. After 2 years, I cannot see any distortion.
I would go for it. Follow the directions religiously. I trimmed mine so there were no distortions as I was getting ready to put the silicone dots on. As I remember, the ends needed slight trimming to lay flush, and the area around the lower radio grill needed sanding to fit flush. You cannot tell mine is there unless you know where to look. I wish they would delete the radio grill as well, but done properly, it looks perfect.
No, I don't sing. Based there for too long.
Old 09-09-2003, 10:41 AM
