Post Strange noise after starting car
This is on my '84 944:
I turn the key to start the car and it starts fine. I release the key (back to the on position) and I hear a wirring noise (doesn't sound like the starter by the way). The noise continues (very steady in pitch, not ocellating) and then stops after 10 seconds. It did that for a few times, and then the sound stays there for 30 seconds now.
Any Ideas? Timing belt? Rollers?
Thanks in advance!
Old 05-21-2001, 09:55 AM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by turtle944:
Hi turtle, hey if your shure it is not the starter you can prove it by push starting the car on a hill.. if it still makes this noise then it might be a roller in the belts going bad have you done any engine cleaning latley?? if so then water might have gotten into the roller or if you have done extensive cleaning then water may have gotten into the throwout bearing in the clutch.water will get in at the speed sensors and rinse down into the clutch and starter..... I hope it is not this as it will require you to replace the TOB and clutch since it is apart........Stan
Old 05-21-2001, 11:51 AM
Post
it could be fuel pump??
Old 05-21-2001, 09:52 PM
Post
Leave the car sitting overnight. Then, turn the ignition switch on, without starting the car. If the noise appears for a second or two, then disappears as the fuel system pressurizes, the fuel pump is the source of the noise.
Old 05-21-2001, 10:00 PM
