EGSMachine's Avatar
Question Air Vane (barn door) MOD
any successes/ failures yet? for sucha drawn out post, i was hoping for some results by now.
e
84-9445m
50% car, 50% tires, 100% driver.
Old 05-22-2001, 05:06 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
I'm on it, school is out in a couple of days...
Wait for an update in the next two weeks or so...
Ahmet
Old 05-22-2001, 11:01 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by 1.2gees:
Hi Ahmet, hey i was reading in a porsche book that one way to increase throttle response in a NA was to move the spring on the barn door one notch looser and adjust the DME for 3% rich any ideas? this might take the place of removing metal.....I was interested in your experiment tho........Stan
Old 05-23-2001, 10:01 AM
1.2gees's Avatar
Post
I'm going to be moving the spring much more then one click, but I'll also drill holes in the 'door' to compensate.
I would think that if anything, you'd need to run the car 3% lean, to offset this. But most likely, this engine can run a bit richer (and closer to it's peak power, farther from it's peak efficiency).
Ahmet
Old 05-24-2001, 08:12 AM
951carter's Avatar
Post
if you crush your stock fuel pressure regulator from end to end you can effectivly raise your fuel pressure also, for free.
Old 05-24-2001, 06:45 PM
Post
Ahmet, keep us posted on the meter mod. i have 3 spares to mess with
Old 05-24-2001, 07:02 PM
