the "motronic" box
when i open up that box under my steering wheel (that say's "Motronic"), i don't know what that whole system is called, i'll call it "the computer". which side do i open to find out what i need to "chip" my car? (i want to know if i'm gonna need FR Wilk's adapter on top of the chip...) do i pull off the side with "motronic" or the other side? because i looked under both covers, and i couldn't see anything but the underside of the boards on both sides...
'82 928S ![]() '85.0 944 Not Awesome - Being Parted Out
Depending on your state you may or may not need the Wilks adaptor board. This lets you switch between stock and performance for smog tests. Other wise you will need to pull the CPU and put a socket in then put the CPU back into the socket.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
well he said sometimes you needed an adapter to make just one chip work. not for the dual chip function.
Oh! Then never nind.
FR Wilk?
85/1 you need adapter, 85/2 none nec.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
are you 100% positive? because, damn, will i get $200 worth of performance from it? will i be satisfied? i'm on a somewhat tight budget especially cause of my recent mistakes...
*** Doing this might break your DME, so take all the antistatic precautions you can, if in doubt dont do it. ***
If you need to be sure then take either cover off, undo the four screws holding the ciruit board down and remove the rubber thingy in the middle of the circuit board, it might be glued down.. The board you just unscrewed should open like a book hinged on one side by a few wires, and you should be able to see all the surface mounted components on both boards, if there are no removable chips then you need to get the adaptor. PS the rubber thingy can be a ***** to get back on. Or alternatively the part number for my DME which did require an adaptor is "Porsche part number: 944.618.111.01 Bosch part number: 0 261 200 015" and i'm just guessing here, but the newer DME's might have a different part number?
89 944 Turbo 115k miles, Stock 96 Range Rover 4.0 SE 130k miles. 84 944 170k miles, FR Wilk Chip, Sold. "Don't listen to me, I dont know what i'm talking about" Last edited by nige944; 09-14-2003 at 11:15 AM.. |
