oil pressure at startup
I've searched the archives and found posts and answers for total loss of oil prime after rebuild.
I seem to have a similar problem - maybe a partial loss of prime? At startup, there is no oil pressure for about 10 - 20 seconds with a knocking sound. The oil pressure then suddenly comes up to a regular level.
Is this a partial loss of prime? and is the fix the same?
Thanks in advance.
sorry - I should add that it is a 85.5 944 NA
Old 09-17-2003, 10:03 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Sounds like the OPRV (oil pressure release valve). there are 2 types depending on year. NOTE: Put vehicle specs in profile. How's that socal?
It is easily removed from the lower front of the oil cooler remove the access cover and remove valve assy. clean and inspect. If you see any rust you will need to re-seal the oil cooler. Should do it anyway. The new style '85.5 and above you will need the alignment tool.
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 09-17-2003, 12:28 PM
SoCal Driver's Avatar
Of all things my no oil problem was the oil filter. I replaced it and have proper oil pressure now.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-17-2003, 03:19 PM
