Post you won't believe it...
My 87 924S runs! After sitting at a garage for 3 weeks, I towed it home, put in a set of new plugs, charged the battery, and viola! I also put in a new O2 sensor, but it still idles rough an is rich... what else could it be (other than the DME)? After it warms up, it idles fine...
Any thoughts are greatly appreciated...
Old 05-27-2001, 01:46 PM
Scott R's Avatar
Post
Have you adjusted the idle/air mix screw? You can do it without a air flow meter, but it won't be as accurate. Also sometimes the screw and throttle body housing get dirty. Take it out and clean it up real good to insure that you have proper air flow.
Old 05-27-2001, 02:56 PM
Post
Where do I find this elusive idle/air mix screw??? Thanks in advance for the help!
Old 05-27-2001, 03:53 PM
