Post torque tube removal
How do you get the torque tube to let go of the flex plate? I have the trans out the bolts that attach the torque tube to the bellhousing off and the bolt out of the clamp inside the bell housing. It's a '78 924 auto. Thanks.
Old 05-28-2001, 06:13 PM
Scott R's Avatar
Post
Should just pull out. Did you put a block of wood between the torque tube and the torsion bar? If you are just letting it rest on the torsion bar it puts pressure on the splines and it won't slip out easy. It needs to be level, also have someone push the clutch in when you extract it, helps to releive the pressure on the disc when you pull the tube out.
Old 05-28-2001, 08:02 PM
Post
No I didn't place a piece of wood on the torsion bar the haynes manual didn't have any info on removing the torque tube for an auto.
It's an auto so there no clutch.
Old 05-28-2001, 08:32 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by kaffine krazed:
Hi Kaff, hey it sounds like you might have an alignment problem like the rear of the engine is laening down so take a small jack and put a small piece of wood tween it N the oil pan and jack ever so slightly till the tube pulls free.....Stan
Old 05-28-2001, 08:41 PM
