Got a new problem...
the left (driver's side) well under the hatch is 3/4 full of water. We've just had major rainfall (6 inches) in several hours. I emptied the well out and did not find any drain holes or plugs. Three questions: is there a drain plug that I'm just not seeing... any thoughts on making a drain hole... any ideas where the water's coming from. The carpet over the bin is dry and I really don't think the hatch is leaking...
early 85 944 na My water cooled flat six is in my motorcycle... |
there are drain holes with rubber plugs on each side, obviously at the lowest points. if there is crud obscuring your view, get underneath the car and remove them there.
_______________ -too many cars |
The rear hatch has two drains just under the spoiler - there are two hoses (one each side) that goes past the brake lights - check to see that the hoses haven't fallen off their nipples - the hoses continue on down and go through a hole in the side. If your hose is loose or missing, it can let water into the hatch area. My '84 944 has a wierd problem of actually filling the brake lenses with water caused by this same hose. Cleaning the hoses helps.
Stay Posted - more to come. |
There is a drain hole and this is supposed to have a rubber one way valve like plug. The large diameter plastic hose going through the storage well is the drain from the sun roof.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
also check the outlet for the hose that drains the sunroof. i used to install sunroofs and if the hose wasnt connected propperly to the drain plug this would happen.
and just an interesting thing i learned while doing it was that ALL sun and moonroofs leak (except top sliders) but they channel the water out of the car with hoses connected at all 4 corners.
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
I followed the hose from the gromet back to behind the carpet. The hose is connected to another hose that comes from the roof pillar. The hoses had come disconnected, so I re-connected them.
We're waiting for Isabelle to hit this afternoon so I hope this fixes it. Thanks for everyone's responses...
