J1NX3D's Avatar
Question 944 Cooked Rings
Hey guys!
One of my mates has a Euro '83 944 5-spd.
Hes had engine temps soaring last 2 times hes driven it, now it won't turn over at all- in his words:
"...temp maxed out for a couple of minutes. Doesn't start now, just screatches and scrapes..."
Questions:
1. Does this sound like cooked rings? If not then wot could it be?
2. Wot other symptoms should he have with cooked rings?
3. Wot is required in parts and labour to fix?
Thanx in advance
mAd
p.s. starter/ battery r sweet
Old 05-31-2001, 01:47 AM
J1NX3D's Avatar
Post
pps, u guys are almost 19hrs behind me!!
Old 05-31-2001, 01:48 AM
88_944's Avatar
Cool
I can't believe he maxed out the temp. He should have stop the engine when it was about 3/4 hot. I think the cam housing or the head is warped. I think it can't be the rings. It's the upper half of the engine that is damage.
PORSCHE There is no Substitute!
[This message has been edited by 88_944 (edited 05-31-2001).]
Old 05-31-2001, 03:30 AM
Lightbulb
Dont freak out just yet, there are a number of things that could be the problem. There is a safety mechanism that does not allow the car to start when the temp is truley at the max of the temp gauge. I had this problem about four weeks ago and it was a simple fix. My problem was that my thermostat had gone bad and locked up. It was not allowing coolant to reach the radiator. I even tried to flush the radiator first, before I realized what the problem was and the coolant shot out the expansion tank. Anyway, I replaced the thermostat with a lower temp one, flushed the system and everything has been great. I also added Water Wetter into the expansion tank to help lower the temp even more. I recommend changing the thermostat first and go from there, they are only around $20. Good luck.
Old 05-31-2001, 10:07 AM
