Dave951M's Avatar
Angry Sunroof limit switch timing & vocab expansion
Has anyone had to take apart the gearbox that retracts the sunroof? The torque limiter on mine was set far to loose to allow taking the roof off. I took it off and tightened the limiter. Now I can take the roof off, but can't get it to go back on. It almost seems that the motor is now 180 out of time with the limit switches.
Dave951M
Old 06-01-2001, 06:01 PM
lm6y's Avatar
Post
Dave, Have you done a search on past posts? A while back it seems like like a lot of people had this same problem. Most of those members are gone now, so a search might give you the answer you need.
I've never had a problem with mine, so I can't help you. Good Luck with it.
Old 06-02-2001, 07:27 AM
Dave951M's Avatar
Post
Just checked the past posts. There was an interesting tech article on a link that describes the system operation. I got the system timed right, but the double micro switch on the rear of the bar seem like there isn't enough adjustment for them. I'm at the full rear position and it seems like it needs about 1/8" more. With the switches unbolted, the arms will retract and raise. I manually operated the switches to simulate the roof acitvating them and they work ok. Again, the problem seems to be not enough adjustment to the rear of the car. I'm seriously contemplating drilling and tapping another mounting hole so I will have the extra adjustment.
Dave951M
Old 06-02-2001, 03:21 PM
