Send a message via AIM to lilwolffeman
trip meter is broken
my trip meter is understating the distance it actually travels. so i have no clue what to do. it's gonna screw up when i change the oil and stuff. any input is appreciated.
85.5 944 NA
Old 09-21-2003, 10:46 PM
I'm willing to bet that you're missing teeth on your odometer gear. Your odometer will continue to run for a little while but eventually stop altogether. If it's that important to you that you know the mileage travelled, you should buy a gear online and replace it. It's not difficult.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 09-21-2003, 11:22 PM
They have some real cheap ones on ebay right now.
Travis
Rennbay, inc. 888-739-7839 x944
Old 09-22-2003, 08:12 AM
ok so i was wrong, both the odometer and the trip meter aren't moving at all. my dad used it and he screwed it up. i'm betting he tried to reset the trip meter while he was moving. so now what can i do to fix it?
85.5 944 NA
Old 09-22-2003, 02:22 PM
The speedo still works... right? If it does, like the previous posts say, buy the odometer gear and replace it. It's not too hard.
'87 944 Maraschino Red Metallic Euro delivery...five speed
Old 09-22-2003, 06:29 PM
i was told by a friend's friend that there is a company near me that is authorized to disasemble the vdo cluster. it is called palo alto speedometer
85.5 944 NA
Old 09-22-2003, 10:59 PM
