Question 924 turbo oil problem
i'm thinking of buying a 924 turbo 1980 but when the engine is up to running temperature the oil pressure drops to 1 and the oil light comes on... i read a post dated 14.02.01 by jon a headed new 924 owner with questions. one of the replies by amcporsche924powerhaus had the problem down to a tee. he said try turning on the side lights to see if that affects the guagues and it does. my question is...... how would i go about correcting the problem. i will do a complete oil change / service etc and maybe even change the bearings. i think it needs a good home..... the body work is excellent. thanks
Old 09-25-2003, 08:49 AM
Check the oil pressure using a mechanical gauge. If it's too low you should remove the oil filter and cut it open; check for bearing particles in the filter element. These engines are pretty tough so if there is a pressure problem the engine is likely to need major repairs.
It may well be an electrical problem, so make sure you can diagnose and verify the fault before doing anything.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-25-2003, 08:55 AM
