"Swepco 503 Fuel Improver" Yeh, or Neh?
Well I was searching the all mighty "DriveWerks" catalog, and I came across this:
Swepco 503 Fuel Improver - Restore lost power and clean your Fuel injection or cabureters. Removes impurities and particle build up. Drive your engine clean! One fuel improver designed for use in both gasoline and diesel engines in commercial/industrial applications and rolling stock. Keeps fuel injectors and fuel delivery system clean and eliminates carbon deposits on intake and exhaust valves. Only 60% burns and 40% remains to lubricate and reduces wear. Eliminates sticky valves, improves compression and dissolves harmful gums. One improver that can be used in a mixed fleet without possibility of misapplication. Cleaning capability improves compression, eliminates sticky valves, and reduces engine wear by dissolving harmful carbon, gum and other abrasive materials. Lubricates the upper cylinders and increases fuel economy. Primary Markets are automotive, constructive and trucking. Primary Applications are high performance automotive repair shops, mobile construction equipment, Over the road trucks and fleet operations. So, I'm asking... Shall I? Or is there any other products out there that are similar that anyonbe recommends over this product? In conclusion... I'm thinking to myself "It wouldn't hurt"... Or am I wrong? Well thanks for your time fellow Porsche drivers. Stay safe. Bye.
85.0 944 Automatic ^ Bending my wallet over at every possible moment. |
Author of "101 Projects"
Our customers seem to like it as much as any other product - the Swepco stuff is very high quality...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
'82 928S ![]() '85.0 944 Not Awesome - Being Parted Out
Swepco makes qualitity product. I wouldn't use anyhing else in the tranny. As for fuel additives Porsche recomends Mobile 1. I used the Zmax and liked it but the cost it is expensive.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
holy crap, i didn't realize the price! i'm definately gettin' some of this stuff.
$4.25 http://www.drivewerks.com/catalog/shopcart/CARE/POR_CARE_swepco_pg10.htm
vott does ziss do?
how does it compare to the Chevron F/I cleaner?
I used GREASED LIGHTNING 12000 mile petrol additive.cleans everything,but every porsche owner should use ROIL GOLD metal condtioner oil additive.Saved m y engine head from exploding when it overheated without me realizing.It was way into the red.Now i have a slightly smaller steering wheel{astrali}and i can now clearly see the temp guage.Do some engine searches to find info and local supplier.Engine now runs like silk.By the way roil gold leaves no coatings on the engine parts
944 guards red 82- slotted rear turbo spoiler- new dash cover- red dials - k@n dropin filter- throttle cam upgrade- astrali wood steering wheel {can now see temp guage}-(www.astrali.co.uk)blue/white fogs {RING}-reversing sensors-alpine cd-roil gold engine protection |
Sorry I ment to write Chevron.
I must not have been paying much attention writing Mobile 1???????
yeh
sea foam, don't do it at home, your neighbors will hate you.follow directions EXACTLY. i also use marvel mystery oil. add to gas,oil, or just pour it all over your car, stuff is awesome,and cheap.be weary of products containing chlorine
84 944 5spd,85.5 auto Last edited by guinnastysassy; 09-23-2003 at 02:39 AM.. |
JK...I use MM oil in my oil at oil changing time just because I hear it is ok. But, my big question is how do you know it actually helps?
83 944 N/A 5 sp. (mine) 90 Acura Integra auto (sons) 2000 Honda Odyssey EX auto (wife) 83 Suzuki LT 125 (4 wheeler) (wife) 92 Honda XR 80 (son) 97 Honda CR 125R (son) 98 Honda CR250R (MINE) 2000 Kawasaki KX 65 (son) 2003 Honda XR 50 (Son and daughter) |
i had an 86 300zx that was misfireing due to build up in the injectors, and i put a quart of marvel in with half of a tank of gas, didn't have time to pull the injectors and clean them properly. i did this as i was leaveing my old job,and had about a 30 min commute to get home.as i was driving i slowley noticed a difference in the performance of the car.when i got home and parked it i left the engine on for a minuit and opened the hood, i had noticed my idle was a lot smoother, it seemed to be running fine. i ate dinner and watched some tv for a while giving the car time to cool. when i went back out side to put it in the garage it instantly started(a first for the car) and put it in the garage. i pulled one of the injectors and was going to clean it and the lower tip allmost looked new so i just put it back and the car continued to run ok. about a week later i used the sea foam in the intake(put a vacume line in the sea foam ). *****very important to follow the directions EXACTLY******. when i started the car the smell was horrible(do it in an open parkinglot, not your front yard, your neighbors will never forgive the horrible smell)the car didn't have a cat(the first thing i do when i get ac car ,but if i get pulled i bought it like that ) and a free flow exhaust and i actually saw small carbon flakes comeing out.the car ran like it had just recieved a major tuneup! that was enough proof for me, i have done the same treatment on every car i have owned and never had anything but good results. all for well under $20
84 944 5spd,85.5 auto |
oh and the marvel actually acts as an octane booster.check out this link or do a search ,i am sure you will find the same
http://tooldesk.com/cgi-bin/webplus.exe?script=/shop/item3.wml&groupid=Marvel%20Mystery%20Oil&prodid=MAV%2D014&deptid=Lubrication&SessionID=2003923121848309
a better link http://www.pipercubforum.com/marvel.htm
What exactly is sea foam? I've never heard of it.
1984 944 N/A 1996 Golf Gl Drive fast. Take chances. If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields |
it comes in a metal canw/ at twist off top,blue and white. they make one for engines and one for trans(just auto i think) http://www.seafoamsales.com/about.htm
So have you tried sea foam in the gas and oil or just through the intake? Which way works best or do you add it to everything?
just like marvel, you can use it on everything,fuel tank, crankcase and through the intake , just make sure you follow the instructions. http://www.seafoamsales.com/motorTuneUp.htm
I was asking for your personal experience. Thanks though I did check out the site. I'll probably try it sometime.
