ds475's Avatar
Send a message via AIM to ds475
ok, you were right, low fuel light is on again...
my low fuel light is coming on again even when it's full or not even near empty. now it stays on continuously instead of blinking, as it did before. how do i fix this?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 09-24-2003, 08:12 PM
You need a new sender unit. It's in the top of the tank, pull up the trunk soundproofing and there it is! Try checking the connections first.
On a 944 the low fuel level light doesn't blink, it just lights up.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-24-2003, 09:21 PM
Send a message via AIM to lilwolffeman
so there IS a low fuel light? i've never let the fuel gauge get too low, i'm afraid of running out of gas on the road.
85.5 944 NA
Old 09-24-2003, 10:09 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
from a previous post im pretty sure i read that once the light comes on you have 2.7 gallons left.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 09-24-2003, 10:21 PM
daveimme's Avatar
Send a message via Yahoo to daveimme
2.7? Hmmm.....for me, that would translate into about 50 miles.....since I only get about 20-21 mpg (gonna test the 02 sensor this weekend).....
I replaced my fuel sending unit since it did not work at all, and it was real easy.......
83 944 N/A 5 sp. (mine)
90 Acura Integra auto (sons)
2000 Honda Odyssey EX auto (wife)
83 Suzuki LT 125 (4 wheeler) (wife)
92 Honda XR 80 (son)
97 Honda CR 125R (son)
98 Honda CR250R (MINE)
2000 Kawasaki KX 65 (son)
2003 Honda XR 50 (Son and daughter)
Old 09-25-2003, 07:55 AM
ds475's Avatar
first of all... low fuel lights DO blink, because i've seen it... is the sender unit that black wire that runs under that metal lip that is underneath the top of the rear seat?
'82 928S
Old 09-25-2003, 03:37 PM
Nope, the fuel light does not blink. You may think it does, but that's only because fuel slosh is moving the float up and down. If you stop the car with the light on..it will stay on and not blink. That is the time to call AAA.
There is no electrical part in the system to make the light blink, the fuel sender is being used as a switch to light the bulb.
Old 09-26-2003, 07:15 AM
daveimme's Avatar
Yeah...it will flicker on and off when sloshing real low......Mine does that and didn't do it before I replaced the sender unit. I notice if I'm kinda low and turning right, it will flicker....but once it gets lower, it just says on......
That's my experience, anyways....
Old 09-26-2003, 08:02 AM
vott does ziss do?
ronin's Avatar
that's about how it should work (but only when the needle actually gets down to 'e')
Old 09-26-2003, 11:00 AM
MrPants's Avatar
does yours have an 'e'? mine says 'R'
84 944 Non Alcoholic
Old 09-28-2003, 02:18 PM
ds475's Avatar
well, even when i wasn't moving, the light would go on and off inconsistently. that stopped, now it's on 100% of the time. and SOMETIMES flickers off for a second. also it does this ALL the time, even when i have JUST filled up with gas
'82 928S
Old 09-28-2003, 02:30 PM
vott does ziss do?
ronin's Avatar
you are correct, I was just using the english colloquialism
this appears to be a problem within the instrument cluster as a defective sending unit would probably give false indications on both the needle and the light
Old 09-28-2003, 03:15 PM
