perfecto951's Avatar
Send a message via AIM to perfecto951
924 windsheild.
Is the 924 windshield the same as a 944 windshield (aside from the antenna)?
I can get one from a junkyard for like 30 bucks and i need one really bad.
1986 951, India Red. (Mine) - Not For Sale Anymore
1987 944, Alpine White. (Bother's)
2000 Audi A6 2.7 Biturbo Melange (Mom's)
Old 09-25-2003, 08:32 AM
It can work, but it's not a direct fit.
I've seen it done, the installer ran a bead about 1" thich of urethane around the frame and let it sit for a few days. Tnen cam back and installed the windshield.
The problem is the 924 windshield is about 1/8" shorter all around then the 944, so there's not much overhang on the A-pillars.
I didn't think that a 924 windshield could be removed in one piece. If they do get it out get a REALLY good installer to put it in. The one I saw put in never leaked, so it is possible.
VT944
Brian
1985.5 944
Dodge Viper Blue on black/tan
white face gauges
throttle cam
short shift kit
Old 09-25-2003, 09:45 AM
SoCal Driver's Avatar
The early 944 windsields and the early 924 windsields are the same. Replaced mine a few years back for well under $200.
I've been told by the installers that the only difference between the early 944 and later 944 windsields is the antenna. The later 944 uses a spacer to repossition the windsield flush with the body work.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-25-2003, 10:25 AM
Wolf1's Avatar
So-cal is this spacer on the later ones replaceable? Could one be installed on an early car to flush mount the glass?
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 09-25-2003, 04:56 PM
As far as I know -- yes. Think the dash might have changed when they installed airbags. This would only eliminate the lower spacer.
This is something I'm considering. Well, was considering till I got rear ended. Put the dampener on a lot of things I wanted to do to the 83. Besides the flush windsield I was going to install the smooth roof line gutters. Also the front fender group from the 86. Even bouthg a stubby antenna to mount on the roof to replace the fender mounted one.
Old 09-25-2003, 05:24 PM
