scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Exclamation WTF? my car is lop sided!!
ok, i have a serious problem... i put my car up on jack stands ( i jacked it up and put stands where a pic from a previous post said to) today to adjust the parking brake. it was up there a while cause i got distracted and did a few other things. then when i was done i put it back down and started driving to my gfriends house for some luvin. on the way i noticed my car handled a lot differently. sorta felt like i had a flat tire so i stopped and checked the tires but they were fine. so i got back in my car thinking i was just being parinoid. but more driving and it just didnt seem right. when i got to her house i got out and looked over the whole thing. when i got to the back i backed up and looked at it from a distance and noticed it was no level... the drivers side was quite a bit lower that the passanger side. there is nothing heavy in the car and i know my weight wouldnt even make it lien that much(108lb). wtf is wrong with it?!
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 09-23-2003, 10:42 PM
springs
When you jacked up the car and took the load off of the suspension the springs probably moved in the spring perch and did not align or seat properly. I would jack it back up and try and align them. Just a thought
Old 09-24-2003, 02:15 AM
paulc's Avatar
i think my torque wrench weighs 108 lbs
87na guards red(mine)
98 suburban(mine)
04 4Runner(wife's)
Old 09-24-2003, 04:46 AM
it should reset it self if you roll the car back and forward a couple of feet
84 944 5spd,85.5 auto
Old 09-24-2003, 05:26 AM
i jacked it back up on the leaning side and as i did the wheels became "untucked"... odd didnt know that could happen
Old 09-24-2003, 03:01 PM
Scott R's Avatar
I think your saying that it's low in the right rear correct? Would you say it's about an 1" low? If so the eccenctric bolt was probably not very tight and now its sitting all the way low on the swing arm.
If thats the case it's an easy fix.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-24-2003, 03:50 PM
ds475's Avatar
Send a message via AIM to ds475
108 lbs!? aren't you a guy? my sister weighs like 120lbs, and she is a twig. although, she's in the drill team, and dances a lot, and muscle weighs more than fat... but damn.
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 09-24-2003, 05:59 PM
yes i am a guy. im 5'6" and i can wear a visor around my waist... literaly! but im not weak, i can bench 145lbs not bad for my weight. i think i fit my car... it is also a lightwieght but powerful... now only if i could learn how to drive so i could autocross...
Old 09-24-2003, 06:06 PM
ds475's Avatar
lighter is better...
'82 928S
Old 09-25-2003, 04:53 PM
