-   -   White Gauges (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/129222-white-gauges.html)
DKillaPorsche 09-26-2003 10:12 PM
White Gauges
Any of you fellas wif the old school 944 dash that have changed their speedo, tacho, even oil gauges from yellow and black to something different??
If so where did you get the kits to do so and how easy/hard was it??
Buddy 09-27-2003 05:56 AM
I assume you're talking about pre 85.5 cars.
I did it and I'd do it again!:)
Got mine off ebay for about $35 brand new. Same ones that Perf. Prod. sells for $120. Took about 3hours, start to finish. If I can find a pic, I'll email it to you.
DKillaPorsche 09-27-2003 07:16 AM
Cheers mate, yer i looked at ebay tonite n found sum, only problem is is that im in Australia and all the gauges are in miles per hour and miles per gallon. Also i couldnt find a set with a battery gauge conversion..
Techmonkey 09-27-2003 06:41 PM
email the guy i think he has them in KPH and KPL.
tomeiche 09-27-2003 11:55 PM
IHad fitted red dial set and new bulbs mainly because everything was so dim i couldnt even see speedo at night.Due to lack of time i paid local mechanic to do it.Bought dial kit from porscheshop uk (0)1215856088 but due to slight differance with later model i lost the little bit which says how much petrol is being used.it swung about that much anyway it was useless.and oil pressure now reads to 10bar instead of 5.Other useful websites www.prestigeparts.co.uk and www.9xauto.com {superb site}
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
