Obin Robinson's Avatar
Red face valve spring compressor for 924?
hello,
i can't seem to find the "proper" valve spring compressor for the 924 valve springs. does anyone know where i can find one of these? the Haynes manual says you need a special one.
thanks!
obin
Old 06-06-2001, 06:10 AM
Post
i used a hydrualic press and a hollow cylindrical pipe (an extender or coupler) with a diameter a tad smaller than the lifter bores, with a home made ushaped cut out at the bottom to get at the keepers, and and plastic wrapped around it so to not scrape the bores,
And with a magnet and pliers going through the u-shaped cut out when the valves popped out, i pulled the little keepers right out, with some practice i got going faster at it....but i think you can get the spring compressors at perfermoance products in the tool section of the magazine.
Old 06-06-2001, 10:22 AM
Post
obin,
made an adapter to fit a craftsman spring compressor. It was basically a cylinder as powerhaus suggested with the pipe but I had an opening in one side for the keepers.
found out that a big C clamp works easier than the spring compressor.
drew1
Old 06-09-2001, 02:43 PM
