Vaccum Lines?
Ive been hearing that the Vaccum lines can cause a lot of problems, and also cause a rough idle. My car has a rough idle and i want to check the Vaccum lines. The only problem is I don't know where they are... the owners manual dosent say anything. Im still new to Porsches, just started about 2 months ago. If anyone can tell me where they are, that would be great!
BTW- Im loving these forums, its full of nice and helpful people! |
What year did you say your car is?
Be helpful and add it to your signiture line. I have a few diagrams I can post that will show you.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Its an 86 944 N/a
ill add it to my little line thing |
Here:
kk thanks, ill check this out
86' Porsche 944 N/a |
the other day i noticed the one that goes to the brake booster had fallen out. it had been like that for a while. i just sorta put it back in the y connector thing and closed the hood. i dont notice any difference with the car. what does it do?
and would replacing all those little maroon colored vaccum line with pretty colored ones cause any problems? hmmm, pretty colors....
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
SoCal,
You got one of those vacuum line drawings for an '86 944 Turbo? Would greatly appreciate it. Mike
'85 944 (wife's car) '86 944 Turbo (my car) '91 944 S2 Cabriolet (date night car) |
Let me check.
Walker I have a few vacuum diagrams for the turbo's. They have a couple of different configurations especially if you throw in boost controllers, dual port wastegates, the octopus delete version for the 86 underneath the intake............ etc
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
If its stock you want this one....
Thanks Alex, looks like what I'm after.
Mike
There should be no problem swappin out the vh lines. I'm planning on using the Silicone Vacuum Hoses (SVH) from this company: http://www.hosetechniques.com/ and probably their intake hoses as well. Hmmm Pretty colors
Louie '85 (Early) 944 - Beater '87 924S - Crunch/Rebuild '76 924 - Long Gone "If everything seems under control, you're just not going fast enough." - Mario Andretti |
Thx Socal...-chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD ![]() 04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP ![]() http://www.eurocompulsion.net |
socal-- you have a vac diagram for the early 944 (specifically for the 924S) I 've got 1 vacuum line no-one seems to know where it goes!!!!
Mucho appreciado!!!
TENSION YOUR SOCKS! 88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING! 87 NA Diamond Blue Metallic ~ Gone |
