vott does ziss do?
ronin's Avatar
Britwrench
howdy,
I'm visiting a friend for a few days and don't have access to any of my manuals, etc. my serpentine broke and I want to be sure I have the proper tension on the new one. do you know the tension for it (and the p/s belt) off the top of your head? thanks
(btw: I kept the old one and am going to bring it next time I see you, it looks horrible and is proof positive that good ole' PW didn't replace all of them even though I asked him to)
Old 09-27-2003, 02:40 PM
SoCal Driver's Avatar
Being able to twist it 90 degrees on the longest section is close enough. Did you find the picture recently posted to line up the balance shafts? Search my recent threads.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-27-2003, 03:05 PM
vott does ziss do?
ronin's Avatar
thanks Hugh. I knew you'd bite
now that you mention it, I do remember something like that. I'll do a quick check. come to think of it, that was just a few days ago, wasn't it?
Old 09-27-2003, 03:17 PM
The official Porsche setting is damn tight then turn the adjuster another two turns. (9.5 on the 9201 tool).
Ok, barbeque time..enjoy the weekend.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-27-2003, 04:37 PM
vott does ziss do?
ronin's Avatar
thanks Mark. that seems about right as I thought the belt was already tight enough using the old 'tried-and-true' when it began to squeal under a/c load. (obviously it wasn't ) that's why I asked as I also didn't want to overtighten it either
Hugh, I couldn't find the thread. don't put yourself out but if you happen to come across it, lemme know. thanks
Old 09-27-2003, 05:25 PM
Here:
Old 09-27-2003, 09:17 PM
vott does ziss do?
ronin's Avatar
COOL! thank you very much. they're next on the list!
Old 09-27-2003, 10:26 PM
"serpentine (belt) broke" = balance shaft belt.
??? Or were you tinking of the polyrib AC/alternator belt.
Old 09-28-2003, 10:29 AM
vott does ziss do?
ronin's Avatar
polyrib. (my bad, thanks for catching that)
I have a bad habit of calling them serpentines as 1) serpentines are usually polyribs (but not all polyribs are serpentines as your point clearly illustrates) and 2) there are two acessories (read: 3 pulleys) on the same belt which subconciously gets me to think "serpentine." of course between the two, the balance shaft belt is the only true serpentine due to the counter-rotation of the second balance shaft and the belt's subsequent serpentine threading. I guess it's kind of like me calling any copier a Xerox no matter what brand it is
the diagram is still very useful as the timing and balance shaft belts are next on my list of things to get done
BTW: if you still have my e-mail, drop me a line with all the details of what you need as I still would like to get a copy of the CDs if they're available. thanks
Old 09-28-2003, 01:00 PM
Serpentine means that it bends both ways. The balance and timing belts do that. The AC/alternator belt doesn't.
Old 09-28-2003, 03:31 PM
vott does ziss do?
ronin's Avatar
zigackly!
Old 09-28-2003, 03:47 PM
And thanks for not buying the belts from me.................................
I will let you off this time. Maybe.
Anyway, what cd are you after? Britney? The Sound of Music soundtrack?
Old 09-28-2003, 08:53 PM
It's a special CD. One of my past times is recovering music from old vinyl albums. I copy these to the computer and remove the cracks, clicks, pop and hiss. Takes about an hour a song as I'm very picky about the finished product.
The CD that Ronin is asking about is the noises from the albums. Yes I save these. I put so much time into removing them it seems foolish to just throw them away.
Interested?
Old 09-28-2003, 10:14 PM
vott does ziss do?
ronin's Avatar
Mark, I would have bought the belts from you but you're not open on Saturdays (so there) :P
as for the CDs. I discovered that playing the noises that Hugh gets off the albums in my car makes an excellent anti-noise to squeaking belts or any other sound that would otherwise seem worrisome.
Old 09-29-2003, 09:51 AM
Noises like sirens and words like "Pull over"?
Old 09-29-2003, 09:57 AM
vott does ziss do?
ronin's Avatar
never heard of 'em!
Old 09-29-2003, 10:29 AM
