CSU944's Avatar
Cool Question for all you welders out there
What is the effect on the 944's electronics when welding (MIG/TIG) on the chassis? I really don't want to fry anything expensive; does anyone have any experience with this?
I have to weld my driver seat rail supports back to the floor pan tomorrow. The engine I just rebuilt is so powerful it ripped the driver's seat right out of the floor (he he he...)
-Tom
Old 09-27-2003, 07:46 PM
What I've heard is disconnect the battery, and hook your welder's ground as close to the area you're welding as possible.
Sam
Old 09-27-2003, 08:12 PM
CSU944's Avatar
BTW, is the floor pan aluminum or steel?
Old 09-27-2003, 08:49 PM
AFJuvat's Avatar
Steel
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-28-2003, 08:40 AM
BlueQuestTSi's Avatar
I've never unhooked batteries when welding on a car...... But then again, I don't recommend doing that either, pull the negative terminal.
Maybe even go as far as what FRWilk mentioned, as no one knows our DME better.
Jack
86 Red 951 - Turbo Twists, otherwise stock for now
83 Black 944 w/86 951 front end - still down and out, but coming back slowly.
02 Altima SE 3.5 - grocery go-getter
00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi
Old 09-28-2003, 04:28 PM
Send a message via Yahoo to bigyagi
pull off the battery negative wire. this will protect against damaging the rectifier pack in your alternator. disconnect the dme unit--very important.
as an alternative, why not consider brazing, or gas-welding?
regards, bob.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 09-28-2003, 05:39 PM
CSU944's Avatar
Because TIG welding is sooooooo much fun!
Old 09-28-2003, 08:12 PM
Burn the fire.
Brando's Avatar
roger that^
i wouldn't take any risks when welding onto the chassis. The electrical components might be as electrically fragile as ever.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 09-28-2003, 09:51 PM
Aluminum or steel????? How about seeing if a magnet sticks to it....
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 09-29-2003, 02:46 AM
anyways, my drivers seat came away, as i was pulling out of my driveway! quite a surprise, as i shot backwards, and had to take a firm grip of the wheel, to keep the seat in position!! had to laugh afterwards,but VERY glad that it did not happen on the freeway instead.
i removed the seat, and found that the nut that fits under the small panel, had pulled thru completely{both sides}. the metal was no good, with cracks, and too much wear, to try and re-seat it .
so, i cut 2 steel strips, about 1" wide x 4" long, 0.080" thick, and rivited them in position, with the clearance hole in, and nut fitted. then, at work, i gas-welded the strips, and no problems! it only raises the front mounting points by 0.080", or 2 millimetres, if you prefer.
anyone not having had this problem, i would seriously ask you to take your drivers seat out, and check the mounting points. you may not be so lucky!!
regards, bob.
1984 944 na.
Old 09-29-2003, 08:21 AM
CSU944's Avatar
That's exactly what happened here, but I haven't had a chance to fix it yet. I'll have time to do it tomorrow.
The PO didn't think this was a big deal....I guess he didn't mind going to full recline when he hit the gas. Good point about checking this stuff, maybe we can talk Porsche into doing a recall to beef up our seat mounts? yeah right......
Old 09-29-2003, 06:49 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
i bet if someone got into an accedent and the seat just 'ripped' out someone here could be a very very rice person... mmm... i smell a law suit...
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 09-30-2003, 10:32 AM
CSU944's Avatar
Well, I got this fixed today. I did pretty much what Bigyagi did, but I disconnected the DME and MIG'd it. No problems with the electronics, and it sure feels nice to have a solid seat under my butt.
Thanks for your advice, everybody!
Old 09-30-2003, 06:32 PM
